right combination??
Old May 6, 2008 | 07:17 PM
94EGgirlie's Avatar
Default right combination??
just wondering in everyones opinion is what i have in my car right now is the right stuff to have....
97 LS motor with a p75 ecu and a ls/b20 wiring harness....
i just want to know cuz my car isnt starting at all...it cranks over, gets fuel/spark/air...but doesnt want to completely start.
the harness i have on the LS came off of the b20 i had before....just wondering if maybe i should just buy a new harness and if so, what one am i looking for?
Old May 6, 2008 | 10:23 PM
mtber's Avatar
The harness & ecu should be working fine.
1. Is the car throwing any codes or is the MIL light on ?
2. What codes is the vehicle throwing ?
3. Did you check the spark plugs to see if they are fouled ?
4. Did you examine the firing order / plug wire order, I have personally seen the chiltons or other cheap manuals be wrong for an integra (firing order list).
5. Was the engine running in another vehicle before ?
There are a lot of variables to look at without seeing a vehicle in person.
Old May 6, 2008 | 10:33 PM
94EGgirlie's Avatar
honestly i dont know ANYTHING about which code is which.
spark plugs are all getting spark and they are all new.
the engine was in an auto teg that was swapped out with something else and it was running.
timing is right on point.
as for the spark plug order, i will check that in the morning.
the only thing that i think MIGHT have something to do with the car not starting is a gut feeling with the harness for some reason.....
if any change, i'll let ya know
thanks for all the help!
Old May 6, 2008 | 10:56 PM
mtber's Avatar
Well if the vehicle is getting spark & fuel it must be the firing order or possibly clogged injectors or no noid signal etc. (presuming your only checking for fuel pressure at the rail.)
If there was something wrong with the harness, the vehicle would usually still start or throw a solid code etc.
Again, its hard to tell without seeing the vehicle in person.
Phearable.net - Electronic Fuel Injection Tuning Solutions - Hondata, Neptune, Crome, Uberdata, Ectune, AEM, Honda Tuning, Widebands, Fuel Pumps, Intercoolers, Turbos, LS/VTEC, ECU Chipping, Chipped Ecus, P28 has a firing order diagram & documentation on checking your MIL codes.
Old May 7, 2008 | 05:35 AM
Alpha's Avatar
Regardless of knowing the codes or which code it's throwing is the car throwing any codes; cel?
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old May 7, 2008 | 02:01 PM
Derka's Avatar
TR Balla Donor Supreme
if you need me to check the codes i will stop by
1998 crv daily beater
Old May 7, 2008 | 11:55 PM
94EGgirlie's Avatar
derek, considering you are the closest one, could you stop by thursday sometime? i'll call ya
thanks guys!
i'll still let ya know if any change
Old May 8, 2008 | 04:12 PM
94EGgirlie's Avatar
its running!!!!
think something is a liiiittttle off....could be map sensor?
Old May 8, 2008 | 05:11 PM
mtber's Avatar
its running!!!!
Generally when there is a map sensor issue, the ecu will throw a map sensor code.
What seems to be wrong ?
Is the check engine light on ?
What was the issue ?
Old May 8, 2008 | 05:26 PM
Alpha's Avatar
What would you know? You're just a tuner
* IP E-Mail
* IP Face Book
* IP Web-Site
