95 teg, 2 issues...
Old May 4, 2008 | 11:46 AM
SpoolinK24Vtec's Avatar
Bada Bing
Default 95 teg, 2 issues...
My cousins 95 LS is under construction an hes hit me up with two questions i cant help him answer...
1st - his fuel line is leaking from the fitting, he said theres no cracks or anything and its torqued to spec.. anyone have any ideas..??
and 2nd - this wire is next to the battery, its not connected to anything and hes not sure where it goes... thanks...
Old May 4, 2008 | 12:01 PM
FC_V8's Avatar
the first question.. put some teflon tape and torque it down tight..?
the second question... that wire goes onto the starter..
Old May 4, 2008 | 02:22 PM
Bada Bing
sweeeeet... thanks bro i appreciate it...
Old May 4, 2008 | 02:50 PM
mtber's Avatar
No, use the proper copper crush washers from the factory.
Old May 4, 2008 | 03:20 PM
My Honda Is Slow's Avatar
No really,....it is
exactly, go buy new crush washers. they are cheap insurance.
the wire goes to the fuse box under the hood. its held in with a philips head screw. theirs usualy 2 right next to eachother.
it could be the starter wire, but the terminal looks too small to be a starter wire. but if the starter isnt working, then that could be the problem. but again, it looks like an ignition wire that goes to the fuse box. there is a little hump cutout in the fuse box cover for it to go into it.
:edit: since it looks like your standing on the pass side of the car holding the wire, thats most likely where it goes.
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old May 4, 2008 | 04:25 PM
zeroboost1's Avatar
New crush washers ftw!
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old May 4, 2008 | 08:00 PM
freakasis's Avatar
i second the new OEM crush washers and the wire going to the fuse box.
Old May 4, 2008 | 08:54 PM
nicklemore's Avatar
thanks guys, o yeah and it was the wire that goes into the fuse box
