having a honda problem
Old Apr 24, 2008 | 09:19 AM
miekb's Avatar
Unhappy having a honda problem
i have an 88 civic with a 94 si motor in it.
ive been having ignition issues since i bought it a year ago.
randomly my car will just keep cranking and cranking and nothing..
most the time, i can just leave for 5-10min come back and it will fire right up.
other times, it wont start for an hour or so and now is one of those moments and im about to take a ball peen hammer and start hulk smashing shit under the hood. (not reli but i wish)
could it be an ecu problem? i have a p28 chip, im not sure what program its running tho..
my distributor coil? i replaced an old one (it was indeed bad) with a used one that tested good but im still having this problem.. maybe it went bad too??
im leaking oil from the o-ring where the distributor mounts on the block but its a tiny leak.
ive replaced plugs and cables a week ago.
my fuel holds 40psi pretty well.
thanks in advance its been driving me insane
Old Apr 24, 2008 | 09:41 AM
marktopia's Avatar
TR Balla Donor Supreme
could simply be ur fuel pump. its either bad or something to do with the wiring to it. check all that out and see if u can find the prob. remeber u should hear or see ur lights flicker from ur fuel pump. goodluck
Old Apr 24, 2008 | 11:18 AM
lilmike13's Avatar
SAVE THE SOHC!
i was having this same problem it was the fule pump i would change that you can get them off ebay for 100 bucks shiped if u need any help lmk.
93 del sol si (project)
88 honda cvic ef (daily driver)
hit me up on fb ( www.facebook.com/stewartracing13 )
TR "Old Skool EF" Member #166
Old Apr 24, 2008 | 11:22 AM
zeroboost1's Avatar
it could be your ignitor in side ur dizy
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old Apr 24, 2008 | 12:58 PM
miekb's Avatar
whats a dizy?
and ill get the fuel pump looked into, thanks
Old Apr 24, 2008 | 01:05 PM
hatchattack's Avatar
dizy=distributor
Sounds like your fuel pump is going. I had a 91 crx si that did the same thing, fuel pump was on its way out.
Old Apr 24, 2008 | 09:33 PM
zeroboost1's Avatar
If the car has been run low on gas it is probley the fule pump because gas is what keeps the fule pump cool also sorry for not explaining myself better .If you look at a trouble shooting guid it will tell you to look at your coil,ignitor ,fule pump and a few other things so hope it helps and gl.
Cory .M
Old Apr 25, 2008 | 04:53 AM
miekb's Avatar
thanks guys ill keep u posted
Old Apr 25, 2008 | 01:42 PM
allmotor91da's Avatar
bored
check the main fuel relay
i miss my db1
Old Apr 25, 2008 | 10:20 PM
YBlegal's Avatar
Broke not Built
^ +1 easiest thing to check....
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
