basic honda question
Old May 2, 2008 | 06:19 PM
dizzythunder's Avatar
Default basic honda question
does a 94 honda ex have a crankshaft pos. sensor or a camshaft pos. sensor? if either one where is it located?
Old May 2, 2008 | 07:38 PM
60-1EK's Avatar
Engineer at the source
It has cylinder position sensor (CYP) and crankshaft position sensor (CKP) and they are both located inside the distributor.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old May 2, 2008 | 07:46 PM
i've tried everything i could think of for my car but it wont start.. besides the main relay what would stop the fuel pump from getting power?
Old May 2, 2008 | 11:41 PM
mtber's Avatar
1. Check for fuel.
2. Check for spark.
3. Check malfunction indication codes.
4. Check fuses.
5. Check relays.
6. Use a factory helms manual to figure out your problems.
