need help with electrical
my car wont start for some crazy reason. i have tried everything i can think of. im looking for any suggestions.
symptoms; fuel pump wont turn on when key is turned
distributor wont give me any spark to the plugs
i just bought a brand new fuel pump, change the dizzy, changed the ecu, changed the main relay. but i still have nothing. The car was running before i sprayed the engine bay with the hose. this is on a 94 civic dx 1.5.
any suggestions would be much appreciated.
id start with trying to dry out any wet plugs. pull them apart and blow out the water. if the main engine wiring harness is disconnected you wouldnt get any spark or fuel. maybe something w/ that happened?
