LS wont start...
Old May 1, 2008 | 10:34 PM
94EGgirlie's Avatar
Default LS wont start...
ok heres the situation as blunt and to the point as i can be.
I have a 97 LS in my eg hatch, that isnt starting. Everything matches, but im not quite sure if the harness is goos for the motor considering it came out of a eg coupe with a b20. i had the b20 with the harness in my car and it has ran before with it, but the point im trying to make is that is that harness going to work on the LS?
Also--
I cant tell if the injectors are spraying...is there anyway i can check?
Last thing--
could any of the problems with my car not starting be because of the ECU? its a p75.
Please, i need all the advice/opinions i can get right now to get this nightmare of mine running.....
thanks, kim
Old May 2, 2008 | 03:11 AM
Jap's Avatar
Jap
VTEC Out
As long as it's an EG harness it should be fine Kim
Does the fuel pump prime ? Did you tighten down the harness ground that bolts to the rear of the thermostat housing ? Thats usually the first thing to look for ...
If you need help PM me i'll do my best
Hondata saves lives
OMGVTEC's Avatar
Retired Moderαtor
you sure your main relay is not bad, is it even cranking?
Old May 2, 2008 | 08:48 AM
allmotor91da's Avatar
bored
does it crank?is there spark or fuel?
i miss my db1
Old May 2, 2008 | 04:18 PM
Thatguysstuff's Avatar
Hey its that guy!!
try dizzy cap and rotor...
my LS was out cold cause of bad rotor...
The B20 harness should work fine.
Old May 3, 2008 | 04:35 PM
Outkasted24's Avatar
** I ♥ Old Skool **
Let's start with the obvious.....
what exactly is happening when you turn the key?
Are you getting spark?
Are you getting fuel?
Is the timing set?
Compression in all cylinders?
Has the motor ever turned over in this car or is it a fresh swap/rebuild?
My Flickr
slam.poke.drop.tuck.dope
Old May 3, 2008 | 05:46 PM
zeroboost1's Avatar
Hey Jeff I sent her a pm and she hasent been on since the day she posted this I was going to help yesterday when I was up that way ill still help cuz I have to go back to the vill to pick that tranny up.
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old May 4, 2008 | 12:10 PM
FC_V8's Avatar
^ ALL very good questions.. just need her to reply back..
Old May 4, 2008 | 08:20 PM
94EGgirlie's Avatar
ok one---thanks for everyones help & advice...
unfortunately i havent had ANY time to check out any of these opinions yet cuz of my shitty ass schedule of being a bartender...grrr...
tuesday is my 1st day off after this long ass weekend, so thats when im going to try and figure out WTF is going on with my car
hopefully by monday afternoon or night i should be picking up a set of fresh injectors and that will be STEP 1. lol
until then, i'll keep everyone posted
Thanks again guys!!!
Old May 5, 2008 | 02:32 PM
clean teg's Avatar
good luck kim everyone is having this problem as of latey mostly to do with the cap or somthing with the ignition
