Over heating
Old Apr 22, 2008 | 07:09 AM
RexSiChic's Avatar
Nitrous Queen
Originally Posted by bobster
Instead of throwing parts at it, try this. Let the car run at idle with A/C off. Raise the rpms until temp gauge says the fan should be on. If the fan is not on, hit it with something like a large wrench a few times and see if the fan kicks in.
Yes, just beat on it. That should do the trick
TR "Old Skool EF" Member #012
91 Honda Crx Si & 03 Lightning clone
~*~Ellie~*~
RIP Cisco Ramos, RIP Brian Nichols
Old Apr 22, 2008 | 07:51 AM
Thatguysstuff's Avatar
Hey its that guy!!
Sounds like a crappy thermostat...
i had to change the one in my accord like 3 times for that problem...
But could be a craptastic radiator to..
I ran a B18B1 in my eg hatch with the stock single slam. radiator and never had 1 overheating problem.... i even had AC!
they do make bigger core raditors.. i have a 1 inch one in my garage.. but the one in my Ek is a 1/2 inch?
dont know why?
Old Apr 22, 2008 | 08:15 AM
omgwtfbbq!'s Avatar
I race sailboats
1 inch core aluminum radiator FTW! I have never overheated, even with the radiator half empty. True story.
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old Apr 22, 2008 | 08:24 AM
project racing's Avatar
formerly lolsrc
try a new radiator cap turn the car on with the cap on let all the air get out of the line once its stops bubbling put the cap on
project racing
car audio
car alarms
turbo rebuilds
tranny rebuilds
nissan and honda motor swaps
even small repairs
done at your place or you can come to me
at good price shared_pm me for price&details
Old Apr 22, 2008 | 01:10 PM
89crxsir's Avatar
210 isn't that bad for a temp. Now at 240 you have problems.
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Apr 22, 2008 | 01:39 PM
bobster's Avatar
thats how to check to see if the fan is working intermittently and ready to stop altogether.
Old Apr 22, 2008 | 05:34 PM
  #17 (permalink)
jlude90's Avatar
aspiring luder
thermos these days, when they fail stick open, thats the problem i'm having, bought a new one...sticks open
i still say radiator, i'm sure there are plenty of ones available here for cheap
Old Apr 22, 2008 | 09:18 PM
  #18 (permalink)
125civicek's Avatar
Really, radiator, thermostat, water-pump, possible electrolosis is an issue with over-heating problems. overheating is a serious problem, especially if you have an all aluminum block and head. Replace the water pump, even if you dont think it needs one. It sounds like you havnt thought of that yet. test. Then follow on thru the list of cooling parts. Simple, Right? Also too far advanced timing will make a engine run hot. When you figure it out, its always like.. Man... I was just thinking that might be the problem... Damn Hippies!!
Old Apr 23, 2008 | 06:52 AM
  #19 (permalink)
hatchattack's Avatar
So just for kix I installed a brand new unit from an 94+ integra, I'm still having the same problem. At idle it starts to overheat, I start driving and the temp drops. Just to recap I've installed a cool temp sensor, temp switch, 3 thermostats, Radiator. System has been flushed,burped,and filled. I'm going nuts.
Old Apr 23, 2008 | 06:53 AM
  #20 (permalink)
brand new water pump too.
