Is my timing off?
Old Apr 3, 2008 | 05:18 PM
TechChild's Avatar
Got Rice?
Default Is my timing off?
Hey guys a made a video of how my car idols, I'm new to this jdm sekret and everything that is on it pretty much. But could my cam cause this it's a milde cam and it didn't do thise before last night. This only happens when it sits at idol for a bit. I think it's my timing or something it also might be running a little rich with the 450 injectors. Any help to get it smoother would help thanks. And yes I know the exhaust tone is bad ass.
Oh and it's got a d16z7 with a turbo cam 450 injectors soon to be exhaust ngk cold spark plugs and a basemapped p28 from vega. [ I know I need a tune but no money so if you want to donate I can pm you my paypal.]
YouTube - V8 del sol
And Alan I know you love how it sounds and I do to but my mom says I need full exhaust or she won't let me drive it, so it's going in for exhaust tommrow 2.5 pipe with it cut off right before the exhaust tunnel turns to go to the axle back. Should sound bad ass still
Old Apr 3, 2008 | 05:51 PM
OMGVTEC's Avatar
Retired Moderαtor
sounds like a vacuume leak or you closed the throttle body screw closed to much
Old Apr 3, 2008 | 06:45 PM
TechChild's Avatar
Got Rice?
I'll open the screw up a little, how do I check for the vacum leak?
Old Apr 3, 2008 | 08:32 PM
sleepinsol's Avatar
starting over
check for an air leak around the manifold or throttle body. spray some carb cleaner on it and if it bubbles then uve found the leak.
Old Apr 3, 2008 | 09:06 PM
jlude90's Avatar
aspiring luder
there are 2 holes on the inside of your TB after you take the intake pipe off, you cover the 2 holes with your fingers, if it dies, no leak, if it still runs, you have a leak, THEN you use the starter fluid and when you spray it and it wants to die, then you've found your leak, but no sense spraying that shit if it doesn't leak
and mine exhibited the same issues and it was a failed map sensor, unplug it and see if it throws a CEL and if your car runs better
also, are you tuned?
EDIT: don't touch the idle screw if you don't have to, mine was a MAP sensor issue and i had the idle screw out and it still wouldn't idle when it got warm, new MAP and voila, runs like a raped ape
Old Apr 3, 2008 | 10:31 PM
sleepinsol's Avatar
starting over
whats your dizzy timing set at? that might make a difference too. if its out of time it will act odd.
Old Apr 4, 2008 | 03:46 AM
TechChild's Avatar
Got Rice?
Alan took it off then put it back on I don't know what it's set at, I think I know whats causing the vacum leak hopefully it solves it on the fuel rail there are three little rubber spacers with studs going thru them to hold the rail on, well I only have one of those spacers in and one of the studs is snapped so I orded them from honda hopefully put them in tonight. It also smells like it has a fuel leak and that is probally the reason or it's just running really really rich.
Old Apr 4, 2008 | 06:11 AM
sleepinsol's Avatar
starting over
set your timing with a light to 16 degrees btdc. that could help.
Old Apr 4, 2008 | 05:41 PM
TechChild's Avatar
Got Rice?
Fixed the fuel leak idleing nice now. Now I just need to to replace my oil pan gasket it's leaking onto the flywheel and spraying it everywere.
