vtec engaugement?
Old Apr 2, 2008 | 11:27 AM
jdmsir's Avatar
Default vtec engaugement?
Does anyone know how to bypass the ecu to let the engine go into vtec without it being warmed up? its a 91 crx with a jdm b16 w/ pr3 ecu thanks in advance
91 CRX Si with jdm b16a w/ direct port nitrous
12.04 @ 110
Old Apr 2, 2008 | 11:32 AM
sleepinsol's Avatar
starting over
u dont want it to go into vtec with a cold motor. itl cold sieze and ull cry. but if you want get ur ecu chipped and have them disable vtec coolant check. then it wont look for a certai coolant temp to go into vtec. wouldnt do it if i were u IMO, just warm the motor up and have at it.
Old Apr 2, 2008 | 11:40 AM
jdmsir's Avatar
i understand that. i want it for that track so that i can cool down the engine inbetween runs and not have to worry about it not going into vtec when i launch it and vtec dosent kick in
12.04 @ 110
Old Apr 2, 2008 | 11:41 AM
sleepinsol's Avatar
starting over
the motor should b warm enough in the burn out box. hell just crank it up n let it idle for a few minutes b4 u run it.
Old Apr 2, 2008 | 11:47 AM
jdmsir's Avatar
but is there anyway to bypass it? or do u even know what im talking about?
12.04 @ 110
Old Apr 2, 2008 | 01:13 PM
sleepinsol's Avatar
starting over
yes. you have to disabel vtec coolant check on a chipped ecu. then it will go into vtec at whatever engine temp you want.
Old Apr 3, 2008 | 06:48 AM
omgwtfbbq!'s Avatar
I race sailboats
+1 it should be warm enough after just sitting in/driving from the staging lanes
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old Apr 3, 2008 | 09:26 AM
89crxsir's Avatar
i would sit in line for 35 min with my crx off and have no problems with vtec not popping. afterward i got a feilds vtec controller and that would let me hit vtec just reving it no matter what temp
Old Apr 4, 2008 | 12:53 PM
silverhonda217's Avatar
i have never had a problem with vtec at the track with my b16 it doesnt take long for it to get warm enough. i think it would be a waste of time. but thats my opinion
Old Apr 4, 2008 | 04:44 PM
jdmsir's Avatar
well the problem is that i do have a problem with it i have the huge stock si rad. in it and i cools off quick and im running a direct port kit on it and i dont want to launch it with the nitrous and have it not go into vtec and hit the rev limiter. i have had it happen and dont want to happen again
12.04 @ 110
