JDM B16 trouble
Old Mar 30, 2008 | 07:15 PM
-OneFastREX-'s Avatar
Growe Motorsports
was using a stock ecu then used chipped pr3 ran even better and faster....but now scince the car runs like ass there is no change when interchanging ecus
Growe Motorsports Racing
C.T. Photography
REP IS ALWAYS APPRECIATED AND RETURNED!
Old Mar 30, 2008 | 07:45 PM
sleepinsol's Avatar
starting over
do a compression test and a leak down test. u could b about to blow a head gasket. also check your timing and make sure thats all good.
Old Mar 30, 2008 | 07:50 PM
Growe Motorsports
compression is 210 across the board.... no leaks anywhere on the motor...
C.T. Photography
Old Mar 30, 2008 | 08:30 PM
sleepinsol's Avatar
starting over
check your timing then. have you had the motor apart at all? cams out?
Old Mar 30, 2008 | 09:49 PM
LS4ever07's Avatar
LS4ever07
Default wiring
the problem is most likely wiring. the person who wired the fan and
shift light in had to have tapped into something they were not supposed
to or improperly connected some wires. i would have to see it to be
100% sure, but if it was fine before that then the is a wiring issue.
Old Mar 31, 2008 | 03:43 PM
4thgenhatch's Avatar
is Stock
Is this still a non obd car or does it have a obd-1 conversion.
ONE^UP
TR "Old Skool EF" Member #027
Old Mar 31, 2008 | 10:24 PM
  #17 (permalink)
vonrobins's Avatar
love hondas ftw
EF's are real sensative with wiring , so id check to see if any codes are thrown or any loose wires at the ecu
._________________________
