foamy oil after build
so i just got finished building the gsr.
Eagle H-beams
JE 9.5:1 pistons
ACL race all around
OEM head gasket
ARP headstuds
gsr water/oil pump(obviously)
turbo setup
blah blah blah..
FIGURED IT OUT:
DONT CONNECT THE LINE FROM THE BACK OF THE THERMO TO THE OIL RETURN NIPPLE FOR THE PCV!
Eagle H-beams
JE 9.5:1 pistons
ACL race all around
OEM head gasket
ARP headstuds
turbo setup
blah blah blah..
FIGURED IT OUT:
You may not have foamy oil, you may just have a foamy leak. Air is squeezing through a leak in your line, and that air is oily, which means it is going to come out foamy or bubbly. As for do you have enough oil, the dip stick tells you that rather nicely.
Fix the leak in your oil line. 50 lbs or oil pressure at idle is good.
Did you already break in the engine with a non detergent oil?
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
well,
check this shit out.
i kep pooring more and more and more water in to the radiator. finally i said, "Fuck this" and turned the car off. put a drain pan under the oil pan and took out the plug......
and out comes 5 million gallons of coolant /oil everywhere.
god damnit that pisses me the hell off!
brand new everything, and to have an internal headgasket leak like that really gripes my fuckin ass.
now i get to pull the whole motor out and tear the head off, turbo kit off, tranny off. and look for where in the hell it all went wrong since i used all new shit.
FUCK
FUCK
that sux to hear . make sure you check that head in case it warped which hopefully it did not.
...91 SMF SCCA
Headgasket upside down?
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
while the engine was running, i took the oil cap off and it sounded like a Gurgling ,burping, bubbling mess. after i just drained everything out, i calculate that i had about 4.5 quarts of oil and about 4 of the coolant jugs of coolant all mixed together in the block/oil pan at once.
again, it wasnt smoking or leaking out or mixing oil into the coolant.
the coolant was disappearing as fast as i could poor it into the damn radiator.
thats kinda what it sounds like. friend of mine had the same shit happen him. motor sounded the same way bubbly, gurggling sound. i would check that before you pull everything out. if thats what it is, you can just pull the head and throw on a new gasket and you're ready to go.
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
R.I.P
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
Stock sleeves?
Did you have the head checked for cracks?
Gracie Barra Clearwater
Do you have an ENDYN catch can setup? Sounds like you have lines mixed up. We actually had a customer with a white turbo Integra do this. Everything the same as you described
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
