Piston Ring ?
Old Mar 26, 2008 | 02:30 PM
hatchattack's Avatar
Question Piston Ring ?
I Just put a b18a1 together with p73 pistons and chromoly rings. I have put about 250 miles on the motor so far and I'm still getting some blue smoke at start up and a lil bit at high rpm. I expected some from the rings seating. My question is should I be worried? I've never used these type of rings before so I'm not sure how long it should take or what? Any help would be awesome. Thankz
Old Mar 26, 2008 | 04:50 PM
DemonCivic's Avatar
who honed the cylinders?
did you check the piston to cylinder wall clearance?
if you have driven 250 miles and are smoking i would be worried. the rings break in and seat a lot quicker than that.
Old Mar 26, 2008 | 05:25 PM
A friend of mine did the honing who works at a machine shop, the clearances and everything were in spec. I didn't use oversized pistons or anything like that. Just a stock set of p73s and the rings with a floating wrist pin set up.
Old Mar 26, 2008 | 07:08 PM
civicized's Avatar
smoke at startup could be valve seals. were they replaced?
Old Mar 27, 2008 | 04:38 PM
valve seals were replaced, I did a complete rebuild I dropped off the head at a machine shop to have it checked,level,pressure, and dipped. It seems like it keeps getting better everytime I drive the car. Still a little uneasy about it though.
