car choking itself? ef with mini me help me!
Old Mar 20, 2008 | 03:16 PM
yoshi06's Avatar
Default car choking itself? ef with mini me help me!
k so before i tell u the problem its a 91 ef dx car was converted to multipoint and obd1 so every wire is right
the motor is a d15b7 with a y8 head skunk 2 cam gear p28 ecu stock
now the problem:
if i give it full throttle its like choking itself like not too much air not enough fuel or vice versa car is smoking but rings and headgasket and oil is new engine has been sitiing before i put it in, any suggestions?
Old Mar 20, 2008 | 03:17 PM
yoshi06's Avatar
also ran compression test and ran 190 all across
Old Mar 20, 2008 | 03:19 PM
EF FREAK's Avatar
reppin' ef's since 1997
does it throw codes?
<<< DAILY DRIVER...
YOU DONT WANT TO SEE THE RACE CAR
OFFICIAL TR "OLD SKOOL EF" MEMBER #059
EF FREAK's Avatar
if it does, what codes r reading
<<< DAILY DRIVER...
Old Mar 20, 2008 | 04:09 PM
yoshi06's Avatar
no codes at all
Old Mar 21, 2008 | 10:26 AM
yoshi06's Avatar
help me
Old Mar 21, 2008 | 05:43 PM
-OneFastREX-'s Avatar
Growe Motorsports
hmmm was it doing it when u were at my shop
Growe Motorsports Racing
C.T. Photography
REP IS ALWAYS APPRECIATED AND RETURNED!
Old Mar 21, 2008 | 06:40 PM
EF FREAK's Avatar
check your injectors...? or the harness? is ur fuel pressure regulator bad? this is all shit u could check.
<<< DAILY DRIVER...
Old Mar 22, 2008 | 09:58 AM
yoshi06's Avatar
no i had a diffrent motor when i went there when i was going home oil pump went out and bam rod knock so i already replaced the motor
Old Mar 22, 2008 | 10:00 AM
yoshi06's Avatar
already changed out fpl with a working ones same problem and already changed out fuel filter and injectors wiring shoud be mint but ill check agian do u think my timing is off? i am backfiring
