break in
Old Mar 3, 2008 | 09:31 AM
  #21 (permalink)
kumar.'s Avatar
wrd.
Originally Posted by civicized
1. 500 miles with a lot of in and out of wide open throttle to 3500 rpms, but only after engine is fully warmed up.
2. Oil change
After that, it's a matter of what you want to do.
It certainly doesn't hurt to keep up the initial break-in procedure but raise the limit to 4500 or 5000 (staying below vtec) for another 500 to 1000 miles.
Change oil again and go vetc.
The main thing is you want to force the rings into the cylinder walls by getting on the throttle a lot. Rings don't bite the walls from their own spring pressure, they flair out from cyclinder pressures getting behind them, via ring gap, gasports. Too easy on the throttle and you don't get the pressures you need to expand the rings.
That said, plenty of engines have been run to the max right after rebuild, but unless you have to race or have to tune, or there is some other reason, why hurry?
Virgin engines like a little foreplay.
Did exactly this. Civicized Built my motor
"Success is 99% failure" -Soichiro Honda
Old Mar 3, 2008 | 09:34 AM
  #22 (permalink)
DD.'s Avatar
DD.
Administrator
I stayed under 4k for 1,000 miles.
Oil Change at 200, 500 and 1,000 miles.
Old Mar 3, 2008 | 11:00 AM
  #23 (permalink)
civicized's Avatar
One other thing - use the best oil filters. Premium grade catches smaller particles. Very important.
Old Mar 3, 2008 | 12:59 PM
  #24 (permalink)
sleepinsol's Avatar
starting over
+1 for good oil filters.
Old Mar 3, 2008 | 01:20 PM
  #25 (permalink)
kumar.'s Avatar
wrd.
Honda Oil Filters?
Old Mar 3, 2008 | 02:02 PM
  #26 (permalink)
jlude90's Avatar
aspiring luder
speaking of filters
Filters - Pure Power! EHP® Lifetime Oil Filter CLEANABLE & REUSABLE (Direct Replacement Spin-on) - PurePower!, Inc.
but i know most people are cheap asses
also you want alot of engine braking as well is WOT
Old Mar 3, 2008 | 09:28 PM
  #27 (permalink)
Drivermod03's Avatar
Break it in on the dyno
Old Mar 3, 2008 | 09:35 PM
  #28 (permalink)
rangcrx's Avatar
engine building &best
Originally Posted by jlude90
speaking of filters
199bucks whos dumb to pay that much for that,guess im cheap and been useing fram for 11years ..there is amillion answer to brakein on a engine everyone does it there own way,just do yours how you feel fit,just remeber your rings will seat with in the first 2 3 start ups and warm up and never heard anything about bearings once the oil has set in there thos are done.but true you do have to do a oil change after the first 5-25miles of the start up that way you will get out the enginelube
i love AUTOZONE
