tig welding crash course needed help please
Old Feb 18, 2008 | 03:17 PM
BABILLARACING's Avatar
Default tig welding crash course needed help please
Ok guys my boss bought a miller econotig welder 220v ,I weld on mig but this thing I can make it weld right, I seen the cd like ten times ,set up the machine the way it said and is not melting the aluminum even in the highest amp set up , we got the 75/25 argon (that what I was told it uses) I am trying to make my oil catch can and it doesn't work when it start to melt it a little is like is burning the aluminum . the only feature I can weld with it is the stick with aluminum rods but I don't like it to much the way it looks . I don't know if we are using the right tungstent and I can even make the damn ball on the tip on the tugnstent? maybe wrong setting I don't know ,any help will be really appreciatted , Thanks....omar
Old Feb 18, 2008 | 03:26 PM
conlyn's Avatar
Resident User
using rods is the best way to go, just practice with them
and when you put a new tungston in, just hit the foot pedal and the tip (slightly ground to a point) should round its self after a second or two, otherwise somethings wrong
make sure you do a cleaning pass before you weld whatever you're going to, it cleans the metal of all impurities and makes night and day difference on weld quality
PS: the base metal you're welding *should* metal a little, you're just adding filler metal with the rod, not actually using it to transfer electric current
never used a wirefeed TIG, so no advice on using it...
hope this helps a little
Originally Posted by dan
granted, people are allowed to do what they want to their car. if it makes you happy or pleases you, do it. just dont expect the rest of us to care, approve, or suck your dick for doing it.
TR Stock Steering-Wheel Crew
Member #001
TR "Old Skool DA" crew
Member #01.8L
Originally Posted by rich4rdee
OH MY GOD NOT A DA
Old Feb 18, 2008 | 03:41 PM
does the rods come in different thicknes? and thanks for the tips......Omar
Old Feb 18, 2008 | 06:07 PM
KJ's Avatar
KJ
bored at work
75/25 is not good to use on aluminum. Always tig with straight argon. I usually weld at around 100 amps A/C when I do catch cans. Don't worry about the tungsten too much, just use a red 3/32 and you will be good to go. The red won't really ball up like the green and it seems to weld better.
Old Feb 20, 2008 | 02:04 PM
thanks kj for the tips.....Omar
