K20 R worth the extra money ??
also leaves u behind another K swapped eg. go with the k20a2. the difference in compression is bearly anything 11.5 vs 11:1. And even with cams, valvetrian, intake manifold and header. the k20a2s seem to make ths same or ifnot more than the k20a with the same mods. My k20a2 motor made 250whp stock block NA. Id buy the a2 and take that money that u saved and get a good header (dtr) and kpro.
9.81@ 155 - turbo street B18 retired SOLD
9.91@ 144 - turbo street 10.94@ 137 225 50 bfg stock block
9.10@169 - turbo street 24.5 mt
9.38@ 144 all motor
8.76@ 176 outlaw street
www.clutchmasters.com
www.tempestracing.net
9.38@ 144 all motor
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
I would get the R. Like you have said the lsd alone is worth it.
In the future ak24 bottom end would be a nice upgrade. Guys in the Honda Challenge series are making 265whp with the k24 bottom end and the type S head... and that's with stock cams.
Patrick -
Patrick -
if you have the money faded, I would definately get the ARRRRRRRR..... because I've ran my friend Tuan's RSX type S with K20a (I/H/E/Kpro) and spanked me by like 4-5 cars out from a roll..... (taken place in Forza 2) or you can just get an LS1 motor and call it a day..
06 Evo 9 MR w/ TBE: 12.89@107 mph
Bone stock 06 Evo 9 MR: 13.37@102 mph
06 Civic Si coupe with I/H/E/CTSC(4 psi)/Reflash: 13.50@103 mph
Bone stock 06 Civic Si coupe: 14.49@95.5mph
well if ur not going to put any money into the car..then i guess its obvious the R would be the better setup..faster/lsd and u can say u have an R...since ur not allowed to put money into it..
lie to her
.. just buy a red valve cover and put the rest of money into the swap!
9.38@ 144 all motor
9.38@ 144 all motor
