car stopped running need help!!!!!
Old Feb 4, 2008 | 05:25 PM
cutty2fast's Avatar
boats and hoes!!
thanx will try that first thing tomorrow, really appreciate the imput
Old Feb 4, 2008 | 06:31 PM
DemonCivic's Avatar
no problem, good luck. lmk what you find and if you need further advise.
Old Feb 5, 2008 | 07:16 AM
cutty2fast's Avatar
boats and hoes!!
alrite i used an old taillight off an old four wheeler and i have no injector pulse, switched wires all combinations (2) and no injector pusle, bulb works fine, even tried a voltmeter, now where do i check, right now im digging out the passenger seat to get to the computer, need info quick its my daily driver
Old Feb 5, 2008 | 07:26 AM
cutty2fast's Avatar
boats and hoes!!
i just dug out the ecu its a pg7
Old Feb 5, 2008 | 09:02 AM
00vtecsi's Avatar
slow ass car
have u checked the resistor box?
HELP:https://www.tamparacing.com/forums/h...er-fender.html
-Tuned Performance-/---------------------------------CentralForidaAutowerks ----->660sw 13th st. ocala<------JJC autoworks--shop forum
tuning,turbo installs,custom wiring tucks, nitrous systems, engine swaps,ecu's,engine building,much more, some of the cleanest, most affordable work around 352-857-2715 jason....
Old Feb 5, 2008 | 09:20 AM
cutty2fast's Avatar
boats and hoes!!
actually no but i just checked the ecu and it wasnt sendin the juice to the injectors i ran a hotwire off the battery and touched the wires that come out of the ecu and to the injectors a couple times and it ran a little so maybe its the ecu or maybe the ecu isnt getting power? which wires should i test on the ecu/ecu harness
Old Feb 5, 2008 | 03:26 PM
  #17 (permalink)
DemonCivic's Avatar
+1 sounds like your resistor box
Old Feb 5, 2008 | 03:43 PM
  #18 (permalink)
cutty2fast's Avatar
boats and hoes!!
is there anyway to check the resistor box, its bolted to the shock tower on the drivers side right?
Old Feb 5, 2008 | 08:45 PM
  #19 (permalink)
cutty2fast's Avatar
boats and hoes!!
getting a new ecu tomorrow ill post with what happens...
Old Feb 6, 2008 | 02:38 PM
  #20 (permalink)
cutty2fast's Avatar
boats and hoes!!
alrite i bought a book and checked the resistor box and the main relay, both are fine, also cpu isnt the problem, any wires i should be checking?
Your fucking slow!!
