EF with swap and a/c?
Old Jan 13, 2008 | 08:32 PM
YBlegal's Avatar
Broke not Built
Default EF with swap and a/c?
hey guys i have a 91 hatch with an LS swap, and i was wondering what i have to do to put the A/C on it? nothing in the engine bay is there, but everything in the car including heater core is intact. what do i need to get dont just say compressor or lines. i know everything i need, just dont know wich specific ones will work in this case... the LS is a B18B1 if that matters....
thanx in advance, and everyone with helpful responses will be repped.
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Jan 13, 2008 | 08:59 PM
nocomply540's Avatar
is retired...
Umm I believe you can get an a/c comp. bracket from hasport to run the stock d series compressor that way you can use all of the stock a/c lines.
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Jan 13, 2008 | 09:02 PM
SmokinS13SR20's Avatar
That ginger...
I checked hasport and didn't see anything about a bracket for a/c lines.
Good luck man.
92 CiviC H/B's Avatar
-Proud Croatian-
i have a a/c fan if you need one.10$.
.TR's OldSkool DA Crew Member #14.
Old Jan 13, 2008 | 09:16 PM
is retired...
Good luck man.
Hasport Billet Mounts
there at the bottom...custom a/c bracket to run your stock a/c system.
So yeah, just aquire all of the stock a/c components for her and your set. PM CARNAG3 with any questions. He's running a full a/c system with a b series swap.
Old Jan 14, 2008 | 03:37 AM
rangcrx's Avatar
engine building &best
i would get the 90-93 integra bracket.you will need a 90--91 integra ac compressor UNLESS you use the 92+ civic connections then you can use a 92+LS comprssor everything else you will need from the crx/civic 89-91 meaning lines relay sensor,and condser
i love AUTOZONE
Old Jan 14, 2008 | 05:48 AM
YBlegal's Avatar
Broke not Built
yes but arent the lines different where they connect at the compressor from a SOHC EF to a integra?
Old Jan 14, 2008 | 05:51 AM
YBlegal's Avatar
Broke not Built
thanx guys, youll receive rep as it will allow me to give it out.
Old Jan 14, 2008 | 05:01 PM
is retired...
^you can use all of the stock d series parts....i.e. lines, condensor, compressor and then you just go buy the bracket from Hasport. The bracket is 200 bones...ouch thats kinda steep....ah well gotta pay to play!
Old Jan 14, 2008 | 08:31 PM
YBlegal's Avatar
Broke not Built
$200 isnt that bad when you consider how much you wish you had it in the summer months.....lol
