dizzy question
Old Dec 30, 2007 | 02:42 PM
Honda_Redemption's Avatar
code 52!!
Default dizzy question
Whats the difference from the obd0 and obd1 dizzy's is it just the plug or is it different internally????
just alittle lost
Old Dec 30, 2007 | 03:13 PM
-OneFastREX-'s Avatar
Growe Motorsports
plugs i do believe! thats why people have conversion plug things.
Growe Motorsports Racing
C.T. Photography
REP IS ALWAYS APPRECIATED AND RETURNED!
Old Dec 31, 2007 | 11:49 AM
60-1EK's Avatar
Engineer at the source
Internally different. Trigger wheel count is off. ECU needs to see a specific tooth count to fire properly. Pre-OBD and OBD1/2 are different.
Plugs are the easy things to change.....it is not just because of the plugs.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jan 1, 2008 | 02:50 PM
code 52!!
thanks guys rep'd
Old Jan 1, 2008 | 03:08 PM
conlyn's Avatar
Resident User
if you run the proper ECU
you can run it
but that its' self either requires another wiring harness, or a conversion at the ECU and the other OBD distributors plugs wired as wel
generally more of an issue then it's worth
but like in my white DA it has a ODB1 distributor because it's a GSR head
so with a ECU harness and the plugs wired in i'm using a obd1 distributor on a true odb0 wiring harness
other things need worked with two
i think the injectors need some harness mods for obd conversion
not sure about the alternator though
Originally Posted by dan
granted, people are allowed to do what they want to their car. if it makes you happy or pleases you, do it. just dont expect the rest of us to care, approve, or suck your dick for doing it.
TR Stock Steering-Wheel Crew
Member #001
TR "Old Skool DA" crew
Member #01.8L
Originally Posted by rich4rdee
OH MY GOD NOT A DA
