Valvelash question?
Mr. Stealyogirl
on
Valvelash question?
Ok i was told TWo different things. If you take the cams out, Do you and Do you not have to re-set the valvelash? I was told Yes, and No. Lmk whats up.
everytime you change your cams setup you should adjust the valves, also that could be very important if you want to take advance of your new setup, the period of time your valves open and close make a huge different in performance.
ANGER+PREMIUM GAS= 20% HP INCREASE
Mr. Stealyogirl
on
Change as in upgrade? Because there the same cams
if you dont gonna change your cam setup the answer its no, but its always healthy, its like oil change and the 3000 miles.......
yea i'v herd that its good to do every so often, kinda like preventitave mantainance (sp) but im pretty sure you dont have to do it EVERY time you take your cams out. but it couldnt hurt to just check it after words. but IMO you dont have to re-do it if you took your cams out
Mr. Stealyogirl
on
Alright cool thanx guys rep givin. I will get it done but i didnt wanna start the motor without knowing.
This is just me but I feel you should always crack the locking nuts and back off the adjusters as far as you can before removing the cams. It relieves tension on the cams as the cam caps are being removed and installed.
Just my $.02
Just my $.02
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
I do the same. It is good practice especially with big cams.
