single cam shaved head
Old Dec 2, 2007 | 07:02 AM
wasrelgood's Avatar
Default single cam shaved head
my compression is low and radiator fluid is getting in some how. so im going to buy a shaved head to replace my stock one.
my question is.. is it bad to put a shaved head on? the head im going to buy is shaved 50 something. when a head is shaved , wat exactlly is being shaved? and is 50 too much?
Old Dec 2, 2007 | 07:07 AM
Evil_GST's Avatar
Pure Evil
Old Dec 2, 2007 | 07:12 AM
wasrelgood's Avatar
i dont know about this .. thats y im askin.. how the he// else am i gonna learn =. u didnt come out ur mom knowin the shi* u know.
Old Dec 2, 2007 | 07:15 AM
Evil_GST's Avatar
Pure Evil
compression has nothing to do with radiator fluid getting into the combustion chamber, you probably have a blown head gasket. what else is done to the motor?
Old Dec 2, 2007 | 07:18 AM
wasrelgood's Avatar
nothing.. its stock. i havnt purchased the shaved head yet. thats wat i am going to get in places of my stock head. and i meant compression being low due to warped head. ( so im told)
Old Dec 2, 2007 | 07:19 AM
Evil_GST's Avatar
Pure Evil
and be careful about installing a shaved head that you really don't know about, they could be shaved wrong or shaved to much. shaved is referring to the surface of the head that meets the block.
Old Dec 2, 2007 | 07:20 AM
Evil_GST's Avatar
Pure Evil
ok the warped head could cause rediator fluid to get in, when you said " low compression" it sounded funny. if the head is warped then you will in fact need a new or shaved head. i don't know 50 is
Old Dec 2, 2007 | 07:22 AM
wasrelgood's Avatar
ok.. wat is the incramens in wich the amout the head is shaved?
hahahahah.. thats the only way i could think to write it.
and the guy said its shaved 50. he said 60 is the lowest u should go.
Old Dec 2, 2007 | 07:27 AM
Evil_GST's Avatar
Pure Evil
maybe .050 of an inch?
and obviously your going to need a new head gasket because the warped head most likely damaged the one on your motor now.
Old Dec 2, 2007 | 07:30 AM
wasrelgood's Avatar
yeah.. i know ill need a new gasket. but thats not gonna be a problem.. i just wanted to know is a head shaved that much going to be relaible?
