Civic Headlight Help!
Old Nov 28, 2007 | 11:30 AM
3m0k1d's Avatar
Can't Take It With You...
Exclamation Civic Headlight Help!
I pulled my dash out the other day and all I did was take out the bolts and unplug all the harnesses, well when I plugged the light switch back on the steering column the running lights came on, when I flipped the switched the headlights didnt come on, the running lights remain on when the switch is plugged in even if I flip them off and the headlights still wont come on. Anyone know why?
Old Nov 28, 2007 | 12:52 PM
stockCRXsi's Avatar
sounds like damaged wires or something was plugged wrong. If everything worked properly before you took out dash, then your problem lyes there.
GL
Old Nov 28, 2007 | 01:10 PM
3m0k1d's Avatar
yea thats what I was thinking but I was hoping not cuz its gonna be alot of work...
Old Nov 28, 2007 | 01:48 PM
stockCRXsi's Avatar
the only possibility that something else went wrong would be a coincidence that it happended while you were doing that, which is very unlikely.
Old Nov 29, 2007 | 07:10 AM
+1, and check for an unplugged connector.-Bob
GL
