Headlights
I pulled my dash out the other day and all I did was take out the bolts and unplug all the harnesses, well when I plugged the light switch back on the steering column the running lights came on, when I flipped the switched the headlights didnt come on, the running lights remain on when the switch is plugged in even if I flip them off and the headlights still wont come on. Anyone know why?
+1, and check for an unplugged connector.-Bob
Quote:
Originally Posted by stockCRXsi
sounds like damaged wires or something was plugged wrong. If everything worked properly before you took out dash, then your problem lyes there.
GL
GL
