noise from front driver's side wheel ?
I don't understand your statement.
At the top of the steering knuckle there is a ball joint that connects to the upper control arm.
At the bottom of the steering knuckle the lower ball joint connects to the lower control arm. Around the middle the tie rod connects with another ball joint to the steering knuckle.
The other side of the tie rod connects to the steering rack at the inner tie rod joint.
Which one has play?
Which one has play?
the bar i noticed moving was at the top coming towards the wheel.
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
Shot at 2007-11-07
Shot at 2007-11-07
i love AUTOZONE
i love AUTOZONE
did some looking at it last night. the movement i was getting was the slight movement that the steering wheels allows. when holding the steering wheel still, i have no play on the wheel by pushing from top to bottom or side to side.
i do have a strpped out control arm bolt on the passenger side and i guess the noise could be coming from that. i swear it is coming from the driver's side. ill fix the control arm bolt and go from there.
98 E36 ///M3 Sedan
07 Civic Si Sedan
98 E36 ///M3 Sedan
07 Civic Si Sedan
Keep us posted on what you find.-Bob
