2 Step
Old Oct 30, 2007 | 11:51 AM
DD.'s Avatar
DD.
Administrator
Alright Thanks John.
Looks like i need to do some adjusting. I may be contacting you about a wideband also.
Old Oct 30, 2007 | 01:06 PM
sleepinsol's Avatar
starting over
yea i have a 2 step and never use it. it just basically allows u to launch ur car at a certain rpm at full throttle bc as long as the speedo reads 0, that particular rev limit will engauge. u only really need it at the track. otherwise ull have to have 2 different 2 steps for the street and track (bc ull hook different at the track).
n +1 on the ectune. much better than crome from what i hear.
Old Oct 31, 2007 | 05:47 PM
jlude90's Avatar
aspiring luder
ectune launch control is pretty neat, but its the kinda thing, if you buy cable and theres a channel you don't watch, you have it for whenever you want it, but if you don't use it it has no bearing on anything
if you are getting tuned, you can set it and if you use it you use it, if you don't you don't
Old Oct 31, 2007 | 06:13 PM
uyht's Avatar
it sounds like it is hard on the car? Is it?
--Its all good--
Old Oct 31, 2007 | 06:48 PM
bugger ill's Avatar
TR Balla Donor Supreme
Originally Posted by mtber
You may want to re-think using crome.
+1
Old Oct 31, 2007 | 06:57 PM
jlude90's Avatar
aspiring luder
a 2step?
no, not really, its pretty much you mashing the gas at a standstill and the ECU cutting ignition at a certain RPM so when you dump the clutch you are at WOT already, and not at a high RPM to just constantly spin the wheels
pretty much like you holding your RPMs at say 4K and then dumping the clutch and flooring the gas, except it does it for you
thats it in a nutshell eh?
Old Nov 1, 2007 | 10:00 AM
  #17 (permalink)
Steez's Avatar
Keep it REAL
eCtune FTW.
Mazda 2 Forums
R.I.P. Pablo 'Fathead' Garcia - Love you man! See you on the other side!
R.I.P. Kevin 'Slo_Si' Gonzalez - You will be missed!
Old Nov 1, 2007 | 01:03 PM
  #18 (permalink)
sleepinsol's Avatar
starting over
^^^ +1
