2nd Rev Limiter?
I would stop messing with the boost levels, honestly. If the car hasn't been tuned for that setup its not safe to run it, period. Fix whatever problems the car has first and then have it professionally tuned. And if you must drive it, i'd keep it out of boost if you like your motor. my .02
he said the car was tuned on 15lbs wit a walbro 255, he sold the pump and put in a gsr, When i got the car it was on 15lbs, he said i would need to upgrade the pump, I knew this. Thats why i turned the boost down and now the pump is working fine on 10 lbs.
Sounds like a tuning issue. Your going to end up with a blown motor if you don't get the car tuned.
nah sounds like you need to close you spark plug gap cuz your boost is blowing out your spark. find out what your gap is at, i usually gap the spark in my turbo motors at .028-.032, any bigger with big boost and you get that magical rev limiter. do you have an MSD or anything like that?
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
btw, i dunno what turbo you are using but a walbro 255 should be able to keep up at 15 psi, it would probably do you more justice to upgrade the line from the fuel pump to the fuel rail.
sorry i read the thread wrong, i didnt realize you took the walbro out, WTF ARE YOU DOING BOOSTING WITHOUT ONE!!!???? lol you should probably get ur hands on one....
Last edited by MightyMaxGS-T; Oct 31, 2007 at 08:57 AM. Reason: I didnt read the thread properly like an idiot...
Get a Walbro 255 hp in and go from there. Something doesnt sound right with the previous owner. He took the Walbro 255 out and replaced it with an oem pump ... ... ...
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
Thats one helluva truck you got hoss! I've wanted to do that with a mitsu truck since I was a teenager.
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
thanks bro, i can build u one if u want...
