b16a turbo help...
stock oem itr valves would do you good. omni's are the same design as the itr's but they are hardened and if anything mishaps occur they will break instead of bending as the oem valves would. sk 2 pro 1 cams do good in turbo motors but i think they would do best in turbo 1.8 liter motors. (from what i have read) good luck. with the itr valves they are narrowed or slimmed down when approaching the head of the valve, this increases air flow. a plus over standard valves.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
oh yeah i almost forgot i got a b and m fuel press. reg. and im getting an aem fuel rail
i got a walbro 255 fuel pump and aem cam gears
msd cap and coil
hasport mount and linkage
and going to get a full tune and its going into a 89 crx with drag radails 205 50 15
what are some numbers you guys think ill pull from my motor?
and what psi will i be safe at?
you should have at least a 300 hp car when its all said and done with. i have a b16 with a t3/t4 turbo in my CRX thats getting a dyno run this weekend. i'll let you know the numbers to give you some sort of idea on where you will be running. good luck.
The 407 was fun, but i'm back in the 727. Hell Yeah!
MySpace
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=35437672
Best Honda Video Ever!!!
http://www.youtube.com/watch?v=LrOmlh38uPE
MySpace
Valves are a waste of money. Spend the money on decent cams. With your turbo and manifold a set of itr cams would be decent as well as an itr intake cam and your stock b16a/gsr exhaust cam.
Gracie Barra Clearwater
