b16a with new cams
Old Oct 11, 2007 | 05:31 AM
sleepinsol's Avatar
starting over
lol yea i think ima slap myne on n then let the tuner play with em when its tuned....
Old Oct 11, 2007 | 05:35 AM
danse's Avatar
Its going to fall flat because you have the cams at +2, if you want move the power band up you need to retard the cams. If you don't have access to a dyno to ensure the change just set the cams to zero or -1 if you have increased the breathing and plan on turning it higher. I have a turbo B16 and am running GSR cams the torque peak is at 7K with this engine unless you are trying for a dyno queen and just a high number you need to increase the area under the curve to make it faster. (average torque gain)
Old Oct 11, 2007 | 05:36 AM
danse's Avatar
Oh and you need to tune for any change in the engine spec's cam degree change, vtec cross over, pipe swap. It will never run right unless you do.
Old Oct 15, 2007 | 03:22 PM
Dev Si's Avatar
Civic Si
if you have a piggy back you can set your v-tec to 6 and your car will run better cause i have a b16b and i have stage one pro series from skunk2 and i had the same problem so i just set the v-tec controller at 6 untill the tune.
Old Oct 15, 2007 | 06:23 PM
FORONDA's Avatar
Street Racing Offical
good info guys ill see what happens and now to find a dyno or a tuner
Old Oct 15, 2007 | 06:28 PM
mtber's Avatar
You can find tuners on https://www.tamparacing.com/forums/h...directory.html
