Clutch pedal to the floor
I get the pedal to the floor every once in awhile. And i've notice that im filling up the resivoir every month or so. So i glanced under the dash and there is some brown gunk on the shaft for the clutch. But i havent checked for leaks. I know im going to try and bleed the system tonite, but any help would be great. And if it is the slave and master how much are both. And i have a 94 civic dx. TY all for the help.
All parts should go together without forcing. You must remember that the parts you are reassembling were disassembled by you. Therefore, if you can't get them together again, there must be a reason. By all means, do not use a hammer. (1925 IBM Maintenence Manual)
You definitely have a leak.
Check the prices on Autozone's website because they vary depending on pieces you buy.
http://www.myspace.com/terry_ho
yeah thats what i was thinking but i have to check were, im not seeing any fluid on the driveway
check the lines too make sure there tight.
Proven Power for all your go fast needs
souns like it is the master but, check and make sure the slave is good because it is alot cheaper
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
mine did the exact thing it ended up being the slave cylinder on the tranny only 15 bucks at autozone check that
awesome thanxs for the help, I saw one at autozone for like 15 bucks
So im gonna try that first then bleed and see if its better.
what should i change first?
could the brown gunk possibly be grease/lube? i would look for streaking
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
