Integra Wont Start !!!!!
it might be your fuel relay or your fuel pump the way you test that is you turn the key and if you hear it the pump works if not your relay can be fried or your pump youll have to test the pump but test the relay first .but if its not that the ecu could be blown that like 400 dallors or a houndred lower or higher .sometimes it could be a simple thing like the damn fuse you welcome for the help dude if you got a sister hook me up lol jp.
Thanks for all the help, i had power but not enough to turn the car over. im still having trouble getting my door panel on correctly and the plastic grommet that pushes down the clutch safty switch. I cant get my finger far enough in there to lock it into place.
The clutch safety switch might keep it from even cranking,
if the battery is fully charged. Take care of it and tell us the results.
The door panel is not related to starting most cars.-Bob
