werid vtec issue
Old Sep 25, 2007 | 07:36 PM
sleepinsol's Avatar
starting over
Default werid vtec issue
ok so i know i have a bad connection on my speed sensor that makes the speedo not read sometimes. when this happens i cant go past 4k bc thats where the 2 step is set at. however, once the engine light comes on, i can go past 4k AND vtec works....now correct me if im wrong but i thought that if the vss didnt work, vtec didnt either. anyone kno what the deal is here??? im baffled by this one. thanks in advance.
Old Sep 25, 2007 | 07:38 PM
mtber's Avatar
It sounds like your ecu is chipped. Considering that it is, your vtec speed check is probably disabled.
Old Sep 25, 2007 | 07:44 PM
sleepinsol's Avatar
starting over
yes it is chipped. sorry i forgot to mention that. so if that is the case, if i have the 2 step removed then i will not need a vss to make vtec work?
Old Sep 25, 2007 | 08:10 PM
mtber's Avatar
Theoretically you are correct, however I have seen issues with a VSS code being thrown & vtec not wanting to engage regardless of the fact that the VSS speed check is disabled. (Rare but has happened on cars running crome).
Cars running ectune, hondata, neptune have never had an issue with vss speed check totally working 100%
Thanks,
John Vega
Old Sep 25, 2007 | 08:12 PM
sleepinsol's Avatar
starting over
it is just a crome base map for now until i get it tuned. ill definately have the 2 step removed since i never use it anyway. btw everyone keeps telling me to bring the beast to you for a tune. can u pm me some details on what you do? ive been to your site and ment to send u a message about it, but never got to it. thank you mr. vega!
Old Sep 25, 2007 | 08:15 PM
mtber's Avatar
No problem. Check your pms.
Old Sep 25, 2007 | 08:23 PM
sleepinsol's Avatar
starting over
done did and replied...thank you sir!
