Anyone see the new issue of SCC?-- Vortech equipp
Old Dec 24, 2000 | 07:12 PM
4sfed 4's Avatar
4SFED4
SCC tested 6 or so supercharged cars in this months issue. One of em was a Vortech equipped Civic Si. This thing was peaky! Max power and max torque were both at redline! It put down 272 wheel hp at 10 psi. Pretty good numbers! This kit was CLEAN. All polished parts and an air to water aftercooler. Looks like pricing is a tad under $4k.
Then it promtply ran a 14.2 @98 mph in the 1/4?!?!? Somethings fishy......Must be spinning the whole way down the track.....
Representing the supercharged VW crowd was a Z-Engineering equipped Jetta VR6. These kits are major dissapointments as it only put down about 212 wheel hp and ran 15.0@98 mph. Awful weak when a Vortech VR6 can put down about 50 hp more and run low-mid 13s with a little tuning an exhaust good cool air and some slicks. Well all the Vortech VR6s except ACMEs anyway.
Larry
2002 MB C320 Sport Wagon 15.4@91
2002 Dodge Neon SE
1991 Dodge Spirit R/T-12.3@117 (at 368 whp) Now 500 whp / 514 ft lb on pump gas
Old Dec 25, 2000 | 07:32 AM
onelove's Avatar
Team Titan
Dont know how that could be fishy the MPH seems to go along with the ET. now if it where 14.2@105 or something I could see that but at only 98 that kind of sucks.
Old Dec 25, 2000 | 07:44 AM
4sfed 4's Avatar
4SFED4
Originally posted by "Someone"
272 wheel hp in a 2600 lb car and only 98 mph?!?!?! Thats whats fishy. That type of power to weight ratio should net something in the 108-110 mph range.
Larry
2000 Nissan Maxima SE 5 speed Mad Max
14.75@94.63 (2.26) - 203 hp/191 ft lb on Spec Rs Dynojet
1985 Dodge Omni GLH Turbo - 4SFED
Engine rebuild in progress....T minus 10 days until liftoff....A few weeks after that and 4SFED goes east to hunt whales!
Larry
2002 Dodge Neon SE
Old Dec 26, 2000 | 07:42 AM
4sfed 4's Avatar
4SFED4
I believe the owner resides at clubsi.com. He states SCC are the ones that dragged the car hence the sorry timeslip. He claims better times were to be had if they had not dragged on a slick airport runway. I think hes just making excuses. BTW Larry what does the torque curve look like? Im willing to bet its equally as peaky...and that motor is peaky as it is already.
John
Tampa Racing Moderator of For Sale Local Scene News and Honda/Acura Tech forums.
vapor.trail@gte.net
Those with golf balls golf.
Those with real balls race.
All about me. Everything youve never wanted to know...
Larry
2002 Dodge Neon SE
Old Dec 26, 2000 | 10:34 AM
4sfed 4's Avatar
4SFED4
The torque curve is SUPER peaky. It rises with rpm all the way to redline! Max torque is at 7900 rpm (redline). Below 500 rpm the car was better than stock but still fairly tame. At 5000 rpm (Im assuming VTEC switchover) it shot off like a kicked cat. The torque curve rose almost vertically! I think peak torque was something around 180 ft lb at the wheels at 7900 rpm.
Ill try to run by the bookstore and get the issue and post a pic of the dyno plot.
Larry
Larry
2002 Dodge Neon SE
Old Dec 26, 2000 | 11:49 AM
4sfed 4's Avatar
4SFED4
Ok John heres the scoop:
I took a quick digital pic of the dyno plot in Sport Compact Car for the Vortech V5 and aftercooled equipped Civic Si. The car also had Comptech headers and Apex N1 exhaust. Boost was reported as 10 psi max.
Vortech Si Dyno
The baseline for the stock car was 142 hp @ 7500 rpm and 102 ft lb @ 7200 rpm. The modified car made 272 hp @ 7900 rpm and 181 ft lb @7900 rpm. The reported quarter mile was 14.4@98.6 mph.
How does this dyno plot compare to a turbo Civic Si at the same boost?
There are a few other supercharged cars in the mag this month as well (Z-Engineering VR6 TRD Solara Neon SRT Vortech Cougar). Ill see if I can get some quick shots of their dynos and write up a brief summary as well.
Larry
Larry
2002 Dodge Neon SE
Old Dec 26, 2000 | 12:09 PM
4sfed 4's Avatar
4SFED4
Heres a quick summary of the other cars in SCCs Supercharged Shakedown
TRD Solara - 14.5@97.8 - 243 hp/228 ft lb - 4 psi boost!
TRD Solara Dyno Plot
Z Engineering VR6 Jetta - 15.0 @ 97.1 - 212 hp/204 ft lb - 7 psi boost
Z-Eng VR6 Dyno Plot
Neon SRT - 14.7 @ 95.8 - 178 hp/149 ft lb - 11 psi
Neon SRT Dyno Plot
Vortech Mercury Cougar - 15.1 @ 92.6 - 212 hp/171 ft lb - 9 psi
Vortech Cougar Dyno Plot
The TRD Solara looks VERY impressive spinning the rollers to 240+ hp at only 4 psi of boost! The Z-Engineering charged VR6 is quite weak at 212 hp as a comparbaly equipped Vortech car (mine!) made about 50 hp more at the ground.
The Neon SRT looks promising for production just as tested. Looks like the sport compact market just got a new rocket entry.
The Cougar continues to disappoint. Not much else to say there......
Larry
<FONT COLOR=#a8a8a8 SIZE=1 FACE=Verdana Arial>This message has been edited by 4sfed 4 on 12-26-2000 at 10:43 PM</font>
Larry
2002 Dodge Neon SE
Old Dec 26, 2000 | 05:50 PM
camryDAN's Avatar
heh just wait til they bring out the smaller pulleys for the TRD S/C!
the smallest pulley will boost 10psi...estimated hp figures close to 300!
but alot of the guys on the camryman forum dont believe our engines can run that much boost without some sort of internal upgrades.
that neon looks pretty impressive putting down similar times to the solaras times. but its already at 11psi to get there. and the solara is only at 4!
well those neons are lighter too
Nightshadow Blue 1993 Toyota Camry
Old Dec 26, 2000 | 06:45 PM
4sfed 4's Avatar
4SFED4
Yep...Ill bet 10 psi would put the Solara pretty close to 300 wheel hp. Itd be a rocket with that. Ill bet a TRD Solara with 10 psi could even beat Mad Max hehehehehehe
Larry
Larry
2002 Dodge Neon SE
Old Dec 26, 2000 | 10:07 PM
4sfed 4's Avatar
4SFED4
i know thiw isnt the place for this but since this topic is about the vortec charger for the new si i thought i woud throw this in i know someone here in town that has one for sale it is under 2 grand it is the complete kit if anyone is interested and sorry for not putting this in the proper forum
teal 94 integra gsr 99 saw blades aem intake &cam gears. moderating since sep. 2000
skunk 2 coilovers
Larry
2002 Dodge Neon SE
