400HP D16Z6 powered Real Time 4WD EF hatch
Old Sep 21, 2007 | 12:06 PM
mtber's Avatar
Default 400HP D16Z6 powered Real Time 4WD EF hatch
Taken from: Honda-Tech.com: Forced Induction: Epic Tuning's 400HP D16Z6 powered Real Time 4WD EF hatch.
Originally Posted by EpicTuning
As some of you remember we had a '91 EF hatch with a stock Z6 engine making 375whp @ 24psi. At this power level it ran 11.41 @121MPH. Since then we had turned it up some more. It made 390WHP with a slipping clutch @26psi. We changed the clutch and ran it at the track @ 28-30psi. The car ran 11.3@127mph. We couldn't run anymore because the car had no roll cage. Instead of turning it into a drag car we and the owner decided to go in a different direction. We wanted to make it all wheel drive, work through the problems and have a reliable 4WD civic for the street. We converted the car to Real Time 4WD from a '89 Civic Wagovan. We used the transmission, axles, driveshaft, viscous coupling, rear differential and subframe. The clutch is a ACT 4 pad disc and Heavy Duty pressure plate. So far at 24psi the drivetrain is holding up great. We have a couple hundred miles and 40+ tire chirping launches without a problem. We will keep putting it through its paces and see what, if anything, breaks. We will have video up shorty along with new all wheel dyno numbers.
This is what a 400 HP stock SOHC bottom end looks like :o
Oil pan clearanced for transfer case.
Trans mount needed to be raised 1"
Viscous coupler mounted
Rear diff mount
New manifold. Shorter runners, undivided collector, front facing inlet.
Cable shifter mounted.
Old Sep 21, 2007 | 12:18 PM
Gixxer's Avatar
Hide your daughters
Man that's some awesome fab work.
Old Sep 21, 2007 | 12:45 PM
poorboy44's Avatar
TR Balla Donor Supreme
wow, thats good stuff. i think that is the most hp i've seen one of these awd converted ef's run without breaking.
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
Old Sep 21, 2007 | 12:53 PM
sleepinsol's Avatar
starting over
........speechless. i think i just shit. man.......sweet fab work and great enginuity. WOW! now theres sumthin to aim for
Old Sep 21, 2007 | 02:22 PM
JR.'s Avatar
JR.
bad ass setup.
98 talon awd automagic
Old Sep 21, 2007 | 02:30 PM
effDOHC's Avatar
About That...
holy shit thats sick
Old Sep 21, 2007 | 04:16 PM
k-mart's Avatar
wow
Old Sep 21, 2007 | 05:34 PM
Outkasted24's Avatar
** I ♥ Old Skool **
You would think with all of that fab work and the sick setup, The Outside of the car would look a little bit better.?!#$
My Flickr
slam.poke.drop.tuck.dope
Old Sep 21, 2007 | 05:40 PM
slizzle's Avatar
has a new plan in action
i can see someone takin the front axles out of it to make it 100% rwd
you gotta get it from the muscle cuz dont nobody owe you nothin
Old Sep 21, 2007 | 05:42 PM
slizzle's Avatar
or an awd accord now hondas can get a good lanch like anything else how much do you think that would cost for a H22 in an accord
