axel question.
Old Sep 3, 2007 | 12:58 PM
oldandbusted's Avatar
Default axel question.
alright the car is 90 std pulled the stock 1.5 with the 4 spd tranny. then put in sohc zc with the trans that came with the z/c, this is where the problem is my stock axels just spin inside the tranny.
So do i need to get si axels or ?
Old Sep 3, 2007 | 12:59 PM
rangcrx's Avatar
engine building &best
you need si/dx axels and hubs
i love AUTOZONE
Old Sep 3, 2007 | 01:24 PM
if i wanted to dig into it couldnt i get the si axels and mate the std hub end of the axel to the si?
Old Sep 3, 2007 | 01:32 PM
rangcrx's Avatar
hmm i think it should work if the bearing on the shaft side are the same size cause you would not have to change the joint side makes sence
i love AUTOZONE
