Question ????
There's two switches on the clutch the top one is the clutch switch just stick a paper clip in the connect real quick and try starting it.
Either that or your starter is no hooked up correctly
Ricky
Ricky
iight bet im gonna try that first thing in the moring cuz the one i changed out was the bottom one and it didnt do nuttin
http://www.facebook.com/WiderWerks
same thing happen to my ef at tha track. my ignition switch went out. wit key on run a wire from tha positive batt to tha starter if it cranks ur best off running a push button to start it up
90 EF-dual point
89 EF crx-b18a1
91 EF SI-mini me
92 EG hatch-s.o.h.c-v
94 EG2-b16 on 75 shot
95 DC2-b18b1 crower cams on 75 shot
90 EF-b18a1 port n polished head
90 EF-9 ZC swap S.I.R front end
08 GD-3 FIT=Super Cleeaann!
90 EF-9 SI B18A1
96 EK ferio
90 EF FoDo
05 UA-6 TL
97 EK coupe
06 FG2 SI
94 DC2
96 DB7
97 EK COUPE F/S
90 EF-dual point
89 EF crx-b18a1
91 EF SI-mini me
90 EF-9 SI B18A1
96 EK ferio
90 EF FoDo
05 UA-6 TL
97 EK coupe
06 FG2 SI
94 DC2
96 DB7
97 EK COUPE F/S
battery fuse?
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school
PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Current Cars
PM me for info.95 Civic EX 4dr- D.D.
iight i checked everything new clutch switch , check all fuses , hooked up a wire to the starter and battery checked, jumped the starter to a battery nuttin but when i tryed to jump the starter coil to get the starter to spin .....nuttin happen my last thing is that the coil on the starter is bad time to get a new starter now if that aint the problem im gonna give up and im gonna sell my car
There's your problem... There are two "plugs" on the pedal. The one thats ontop (which is a B*tch to get to) contacts the clutch switch! The bottom "plug" that you changed = The Cruise Control
... I would go to Honda and buy another "plug" and install it on the upper hole (located on the top of the clutch pedal!)
Good Luck,
-Chris
... I would go to Honda and buy another "plug" and install it on the upper hole (located on the top of the clutch pedal!)Good Luck,
-Chris
yea the starter i put in i thought was good cuz i had it sittinin my garage but it turns out to be bad
Good Luck,
-Chris
-Chris
