full throttle bogging...any ideas?
Old Aug 11, 2007 | 08:52 AM
mtber's Avatar
Originally Posted by alwayzblazed
ok maybe im confused but is mtber...john vega?
and yes still running msd
Yes. Concerning the msd, I would recommend you remove it or you atleast bring a stock distributor that you know works perfectly to the dyno with you.
Like we discussed 1 out of 5 msd setups I see end up having to be pulled off.
Old Aug 11, 2007 | 08:48 PM
Old Renegade's Avatar
Cool Runnings
PULLED MY MSD OFF. did not fail me but was recommended too casue they are really not needed unless you are way up there in hp and they can potentially cause problems. all i have from it now is the external coil.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Aug 12, 2007 | 11:58 AM
oldandbusted's Avatar
Originally Posted by ugly86integra
it could be lots of things especially on a swap situation, but i would start out simple with checking fuel pressure. if it's really bogging and not sputtering, it's prob. starving for fuel. clogged up fuel filter is a very common cause for this. check it out and get back with us in here. you can also call me if ya need some help. my #'s in my sig.
i would change fuel filter quick and cheap. i have had that problem a few times
Old Aug 12, 2007 | 05:51 PM
alwayzblazed's Avatar
Get'em Started Early
i will make sure we have the stock cap and rotor .. i will most likely do that tomorrow anyway..i will have all info regarding pistons,injectors .thanx again
Old Aug 12, 2007 | 10:09 PM
customkid72's Avatar
check grounds an tbps sensor
seffner meet getting started so click here to get inhttps://www.tamparacing.com/forums/local-events/745189-seffne-meet-lets-get-something-started.html
*ad removed*contact admin@tamparacing.com to ADVERTISE on here....
Old Aug 15, 2007 | 07:19 PM
jst4shw's Avatar
change the rotor and dis cap. it happened to me b4
jst4shw Store: HID's-LED's-STICKER's-Tshirt's-JDM GOODIE's
TR shop
Like us on Facebook
text/call 813-407-3314
TR em1 crew #1
TR " eg6 " crew #1
Old Aug 20, 2007 | 12:21 PM
  #17 (permalink)
John vega found out is was the Vehicle Speed Sensor..
I dosn't matter anyway found out also there is no compression in any of the cylinders.
Old Aug 20, 2007 | 12:24 PM
  #18 (permalink)
mtber's Avatar
Speed sensor was intermittently working causing the 2 step to malfunction.
Concerning the lack of compression in the cylinders, good luck with the machine shop that built the motor....
