Tranny Question D15
Tranny Question D15
i have a auto matic dx civic hatch eg. I just bought a 00 single cam ex tranny.. The mount brackets at diff for the 00 than the 92. u know? i was just wonderin if anyone has attempted this swap or anyone that can do it. because from the looks of it. im gonna need some welding. so if u have any tips for me and know someone that can do the swap PM me plzzz! i have cash money. i want this done asap
You are removing an auto and installing a manual, or another auto?-Bob
Re-engineering Brackets/mounts To Make Something Fit
When I see the two brackets together, I can find a way to combine them
so that everything lines up.
This also has to be done with some motor swaps when a person doesn't want to spend a lot for special mounts, ....and the same principle applys to tranny mounts. I just re-measure things and re-engineer it for a
solution...........without it costing a lot.
Recent example: a Prelude had only one bolt holding the
motor-front in 'cuz the motor swap shifted the motor to one side.
When it left, ALL motor mount bolts held it in, and it was
lined up as intended.
By re-engineering mounts on some cars brought to me, I have eliminated
vibration problems as well. If you want the problem solved and everything lined up, get back to me. I will need a phone number to set a
day/time.-Bob
He asks:
ok. i am removing and auto tranny and putting in a manual tranny.. my hole concern is the motor mout bracket. the auto bracket sits to the frame and goes up at an angle. the car it came from with the manual bracket sits to the frame and extends straight out.. u know wat im sayin. ? i need a soloution
day/time.-Bob
He asks:
