crv swap
i have a 94 honda civic coupe just need help with some things i want to do the crv swap for it and the motor year is 97-2000 but iono what axle to use and what to do to drop it in and what harness i need and ecu please help thanks
Hybrid: 5G TECH
You need either an LS, GS-R, or B16 hydro tranny with axles to match. ECU you can run a chipped P28 or a stock obd 1 LS. Not sure about B20 having a knock sensor, but if it does you add that and your golden. If you search for an LS swap into a 5g civic, it's just about the same. Also if you get the giraffe IM on the motor, you need to replace with one that will allow you to close your hood.
Shut yo ass up nugguh..
ReginaVagina
ReginaVagina
A chipped non-vtec p05/p06/pr4/p75/p28 would work just fine...
