wiring vtec to switch please help
Old Jul 26, 2007 | 03:43 PM
crazybuck21's Avatar
Default wiring vtec to switch please help
i got a z6 vtecin a crx si. i am using a stock computer p6 i finally got the car running.now i would like to hook the vtec up to a switch with out the computer.any info would be appericated thanks.
Old Jul 26, 2007 | 03:57 PM
hondachris1994's Avatar
hatchback1994
here's some good info, dont hook it up to a switch. Honda designed vtec crossover for each vtec motor so let the ecu control the vtec, or get iit tuned
Old Jul 26, 2007 | 03:59 PM
ok thanks. i think im going to try and get a pr3.
Old Jul 26, 2007 | 06:39 PM
My Honda Is Slow's Avatar
No really,....it is
do not wire it to a switch. you will be better off without it if your going to use a switch. just get the right ecu
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Jul 26, 2007 | 06:41 PM
CivicRacingFL's Avatar
Dorado, PR
get a p28 and a obd1 to obdo harness and you will avoid headaches
Old Jul 26, 2007 | 07:07 PM
FC_V8's Avatar
+111111^^
Old Jul 26, 2007 | 07:09 PM
60-1EK's Avatar
Engineer at the source
It's OBD0 to OBD1. Not OBD1 to OBD0. You always reference the chassis side you are going from to the ecu side you are going to.
And to the OP, don't wire your crap up to a switch.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jul 28, 2007 | 01:32 PM
ONE SICK EK9's Avatar
the switch is the worst and most ghetto thing to do get the ecu and harness spend the money to get it done right every time you go cheap you always spend more money trying to correct it
