Stupid car won't start, taking bat to car in 1 hour
Old Jul 27, 2007 | 04:42 PM
  #41 (permalink)
elitist's Avatar
TR Balla Donor Supreme
Haven't picked up the main relay gonna go pick that up tonight.. gotta a new dizzy and that didn't do it.
Old Jul 27, 2007 | 07:32 PM
  #42 (permalink)
civicized's Avatar
You need to backtrack very carefully. Your car ran, you cleaned it and replaced the rotor. Somewhere between when it ran and when you made changes/disconnections, etc, you likely did something. Difficult to say what, but if you have spark and fuel to the cylinders, your car will fire - UNLESS
it is flooded or the spark is off time. Remember, you do not always throw a code when you have a sensor problem.
My money is on the TDC sensor, Crank position sensor, circuits - something that would affect the spark timing. We assume you didn't cross plug wires, which of course would cause the problem.
It doesn't have to be the sensors themselves, and as you've changed the distributor, it probably isn't. The wiring and the ECU with respect to spark timing could be the culprits.
Still can't get away from the fact that you messed around under the hood and changed the rotor and since then it doesn't start. Have to think if you traveled back in time and didn't do what you did, it would still be running. Think, think, think. It's something you touched.
Old Jul 27, 2007 | 07:41 PM
  #43 (permalink)
0 0 0's Avatar
stop by in the morning...
Old Jul 28, 2007 | 11:46 AM
  #44 (permalink)
elitist's Avatar
I heart Sutton, the car somehow skipped 8 teeth! but it did it upon start up so the car never had ignition so it didn't do any damage luckily. Anyways all fixed up!
Old Jul 28, 2007 | 01:42 PM
  #45 (permalink)
clean teg's Avatar
wow and no clapping of valves to pistons
Old Jul 28, 2007 | 08:25 PM
  #46 (permalink)
elitist's Avatar
nope I am soooo sooo very lucky lol
Old Jul 29, 2007 | 07:29 AM
  #47 (permalink)
Pyroproblem's Avatar
Porsche Tech/Honda Tech
how in the hell does an engine skip 8 teeth when changing out the rotor?!
just wondering what happened?
Now residing in Atlanta.....
Old Jul 29, 2007 | 12:22 PM
  #48 (permalink)
oldandbusted's Avatar
pics of bat marks!!!!
Old Jul 29, 2007 | 07:22 PM
  #49 (permalink)
elitist's Avatar
Wasn't because of changing the rotor just a coincidence.
