Stupid car won't start, taking bat to car in 1 hour
silly question, but was it starting ok before you changed the rotor? If so, for the hell of it, put the old one back in and try it.
TR "Old Skool EF" Member #012
91 Honda Crx Si & 03 Lightning clone
~*~Ellie~*~
RIP Cisco Ramos, RIP Brian Nichols
~*~Ellie~*~
Wellllll I didn't wash the engine bay, just wiped it down and the dizzy is perfect, all the screws are there, cap is tight etc.
BUTTTT I forgot to add one important part to this whole thing lol. I took the dizzy off and put a new rotor in because the old one was kinda messed up. The car is DEFINITELY getting spark though, the injectors have power, and it is getting fuel to the rail. Any ideas now?
2. Are you throwing any codes? If so, what codes ?
3. Resolve the codes if they relate to a major issue/sensor.
4. Double check your firing order (spark plug wires maybe on wrong)
-Yup it was firing just fine before
-Yes I put the old rotor on and tried it
-Yes I tried having a friend start it while I rotated the dizzy
-Yes I actually put brand new iridium laser etched plugs and brand new wires on it
-Nope, not throwing any codes
-triple check my firing order
this is pissing me off!
BTW Vega I have a obd2-obd1 conversion harness and vigin p06, eventually when this thing ever runs I'm gonna have you do a street tune on it since I heard you are doing them again
Make sure fuel is coming out of the injectors, not just getting to the rail. Broken timing belt??? You're getting air, fuel and spark....That's all that's left. Check your grounds.
Shut yo ass up nugguh..
ReginaVagina
ReginaVagina
yeah lol check the timing belt.... I doubt its that, but worth a try..
take the injectors out and make sure they are spraying fuel..
If the car is getting spark, getting fuel.... Is your intake clogged? is your exhaust clogged?
After that idk what to tell you bro, you said its getting spark, the wires are in correct order, its getting fuel, none of your fuses/relays are blown.. The only other thing I can think of maybe when you changed the dizzy your accidentally unplugged a wire harness from the dizzy?!?!? even though you said its getting spark.....
IDK..... GL
IDK..... GL
Tried all of that, and nothing is clogged, all the plugs are plugged in (only one plug for the dizzy since it's obd 2), everything is perfect that's why I don't get it.
Ricky I might try do the fuse box thing I dunno if I doo I'll give ya a call thanks!
O yea, the bat marks look very nice
Damn thats a tough one! Hope ya get er worked out. You really didn't take a bat to the car did ya? I kicked my door once when I was mad....boy did I regret that when I calmed down...
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
