swap question gsr into a eg ex
got some questions bout a swap im goin to do in my 94 eg ex coupe its a 2000 gsr wat all would i need to put it in my car?
Try advancing your brain a few degrees, because it is definitely too far retarded
but i heard u need the b-series shift linkage um gsr rear mount and also the motor is obd2 is that it?
wat im trying to figure out is will my z6 engine harness work with the gsr also will i have to change ne wiring because the motor is 0bd2 also wat mounts
Your Z6 harness should go right onto the GSR, since an EG has basically the same engine bay as a DC teggy you will just need stock integra mounts. You'll need stock GSR axles, stock DC integra shift linkage, and from there everything should be pretty much plug and play.. very very very very easy swap.
well c i was doin alot of research and they all say to use the obd2 gsr engine harness lol so im fuck**g clueless
so even if the motor is obd2 my harness will work cuz everybody elso tells me to use the obd2 harness lol and said i can use my stock singlecam mounts?
