swap question gsr into a eg ex
Old Jul 24, 2007 | 01:47 PM
elitist's Avatar
TR Balla Donor Supreme
Use your obd1 harness, the obd2 harness will not work. IMO always whenever you do a swap always use the harness that came with the car even if you have to add a few sensors change plugs etc. simply because that harness matches you chassis harness. Your stock single cam mounts might work I honestly can't remember off the top of my head, but I'm sure someone will know.
Old Jul 24, 2007 | 01:53 PM
singlecam_oncrack's Avatar
BOOSTED DC4
but if i have to change clips then i need wat harness lol this is a pain in the ass
Try advancing your brain a few degrees, because it is definitely too far retarded
Old Jul 24, 2007 | 05:36 PM
elitist's Avatar
Everything should plug right in A ok
Old Jul 24, 2007 | 06:09 PM
FC_V8's Avatar
if the gsr is an obd-2 and your using a obd-1 vtec harness you would need to change your obd2-altenator,dizzy,injectors into obd-1,.....
Old Jul 24, 2007 | 08:05 PM
elitist's Avatar
mm didn't think about the dizzy.. you are right butttt I don't think you would have a problem with the alternator and the injectors should plug right in.
Old Jul 24, 2007 | 08:30 PM
BOOSTED DC4
well msd makes a conversion harness for the dizzy i already have that lol just need to know 100% that my z6 harness wil work
Old Jul 25, 2007 | 03:11 AM
  #17 (permalink)
elitist's Avatar
Just take one of your injector clips off your car now and take one injector from the gsr and see if it will plug in.
Old Jul 25, 2007 | 08:34 AM
  #18 (permalink)
BOOSTED DC4
i know it wont lol cuz the gsr is obd2 obd1` clips r diff
Old Jul 25, 2007 | 08:46 AM
  #19 (permalink)
BOOSTED DC4
Old Jul 25, 2007 | 08:49 AM
  #20 (permalink)
BLK94EGCOUPE's Avatar
some nissan
bro the harness will work put the damn thing in already
