Motor mount Q.......
Old Jul 12, 2007 | 10:02 AM
FC_V8's Avatar
Default Motor mount Q.......
Alright i have a set of Avid motor mounts.. My tranny mount is going bad so if i change it to a stock mount would this effect anything.. Would different kinds of mounts mess me up...?... lmk thanks
Old Jul 12, 2007 | 02:58 PM
itsslow's Avatar
I-VTEC, do you?
different mounts will not hurt a thing. You will notice more vibrations coming into the car if you got stiff mounts, but you will also notice much better throttle responce with it.
Old Jul 12, 2007 | 04:59 PM
FC_V8's Avatar
yea i just had these mounts installed and i felt lots of vibration.. then my tranny mount fucked up on me...
so if i had 2 solid motor mounts and 1 stock.. it should be fine..?...
Old Jul 12, 2007 | 05:23 PM
chi town brat's Avatar
! Ne shab'rud'ni !
I have a rear solid mount in the back of my crx b16a with no problems to date
the only thing i can think of is sometimes aftermarket mounts will place the engine either forward or further back than the OEM mounts so you may find this to be an issue when trying to use the OEM transmission mount, though it may or may not be by much
Old Jul 15, 2007 | 06:39 AM
To overcome a slight motor mount misalignment,
with a single bolt standing up, you can always slot
the mount, or drill the hole larger, and put a bigger flat washer under the bolt.-Bob
