H22 into an EK 99-00
Old Jul 12, 2007 | 12:10 PM
KJ's Avatar
KJ
bored at work
Nope drain the fluid then loop the line. Done.
Old Jul 12, 2007 | 01:02 PM
tranceologist's Avatar
TR Shop Mod
ok cool
now for the axles
my buddy had 94-01 teg axles on his eg if i remember correctly
with this site it says use - 1990 Manual Accord Intermediate Shaft
- Left and Right 90-93 Integra Axles (with prelude inner cv joint on the right axle) ??? WTF ???
Honda-Tech.com: Hybrid: [FAQ] ***H22A into Civic EG/EK INFORMATION Post all H22A Hybrid info here***
Old Jul 12, 2007 | 01:15 PM
KJ's Avatar
KJ
bored at work
You can use the 94 teg axles if you use the prelude int. shaft. I think the 90 axles with the accord int. shaft is a better setup and binds less.
Old Jul 12, 2007 | 03:38 PM
brax90si's Avatar
Here is a write up I made of a F20b into a EK hatch, using a GSR transmission with the H2B kit.
https://www.tamparacing.com/forums/h...ld-how-do.html
The F20b is exactly the same casting block, and head as the H22a, but is destroked to a 2.0L....
This isnt the normal H22a swap into a EK, but better since you put a shorter geared tranny on the motor. You retain stock b-series axles, shift linkage, tranny, starter, and mounts.
Good luck.
-Braxton
