removing alt from b series crx
Old Jun 22, 2007 | 08:45 AM
JoKiE crx4294's Avatar
popeye built!
Default removing alt from b series crx
Can You Remove It Buy Taking The Oil Filter Or Do You Have To Take The Axel Out
Can't spell strength without tren
AAS...It's whats for dinner
Old Jun 22, 2007 | 08:53 AM
slo_hatch93's Avatar
TRShops Administrator
you can also do it by moving the master cylinder
9/13/06-R.I.P. Kevin aka Slo Si, you will be missed
06-07-2006 01:47 AMSlo_Siwhen the spinnin ends, the bullshit ends...
xbox 360 gamer tag slohatch93
Jap Tuned!!
Old Jun 22, 2007 | 02:11 PM
Jason.'s Avatar
I've always just pulled the damn motor, b-series into EF's come out so easily..
2011 Kia Optima SX Premium/Touring package
Old Jun 22, 2007 | 04:43 PM
KJ's Avatar
KJ
bored at work
Why pull the motor when all you need to remove is the axle and intermediate shaft?
Old Jun 22, 2007 | 04:44 PM
Jun_Tuning's Avatar
VTEChnician
+1
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
Old Jun 22, 2007 | 04:51 PM
popeye built!
So What About The Oil Filter Method? Will That Work Or Not. Just Asking Before I Start Working On It. Iv Always Pulled The Axel But Wondered If I Could Just Remove The Oil Filter Instead
Old Jun 22, 2007 | 08:53 PM
crix's Avatar
:mugen member:
2bolts the easiest way dont disconnect the lines tho
Old Jun 23, 2007 | 07:19 PM
popeye built!
Yea So I Just Moved The Master Cylinder And Alt Came Right Out. Alot Better Than Taking Out The Axel
Old Jun 23, 2007 | 09:43 PM
Old Renegade's Avatar
Cool Runnings
i can be taken out without taking out the axle (i've done it) but requires a lot of wiggling and patience. but just take out the axle. easy as pie.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Jun 25, 2007 | 11:57 AM
I just swapped a few of these this week....................darn it.
...........but not your specific car.
The oil filter trick did not work, since I needed clearance between the engine block and the subframe. Shifting the alt to the oil filter area didn't get that clearance for me.
I popped the upper ball joint, and the coilover pinch bolt, effectively dropping the axle lower, without removal.-Bob
