sohc vtec conversion?
Are you using a obd0 to obd1 harness ?
If so, it should have came with instructions.
Who made the harness ?
Not all harnesses are the same.
You need a obd0 to obd1 jumper harness to make your life 10x easier.
You may save a hundred dollars, however your going to hate your self when one of your solder connections or wires are not properly configured.
Good Luck
Good Luck
