whats a good aftermarket ls cam
Old Apr 24, 2007 | 07:56 AM
Honda_Redemption's Avatar
code 52!!
Default whats a good aftermarket ls cam
I want to see what's the best one I can buy is
Old Apr 24, 2007 | 07:59 AM
Alpha's Avatar
Stock pistons/compression? What intake manifold? What header?
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Apr 24, 2007 | 08:11 AM
code 52!!
Stock b20 block skunk 2 intake mani and DC header I plan to upgrade the valve train
Old Apr 24, 2007 | 08:31 AM
sleepinsol's Avatar
starting over
croqwer makes good cams...how big u wanna go?
Old Apr 24, 2007 | 09:22 AM
code 52!!
Not sure but I want to make some more power
Old Apr 24, 2007 | 09:29 AM
vonrobins's Avatar
love hondas ftw
crower
._________________________
Old Apr 24, 2007 | 10:16 AM
sleepinsol's Avatar
starting over
if i were u id just get a vtec head....ull make more power that way than u will with a crower all motor ls cam.
Old Apr 24, 2007 | 10:59 AM
Lookin2GoFA$T's Avatar
Team 'Petersburg Puller
Static CR & Intake Cam Duration Relationship - Team Integra
more info from team-integra @ Engine Package : Swapping Parts For Power - Team Integra:
Camshaft Choice: With the piston geometry described in 1. , B18 engines like Long Duration, Big Overlap Cams because we need more scavenging and time to fill the chamber, especially at high rpms .
eg. of high overlap cams :
- for the B18A/B Crower 62403 or 62404.
- for B18C Toda Spec B, Jun Type 3, Skunk2 Stage 2, Crower 63403, Zex 57300.
The exception to this rule is when we add nitrous, a turbocharger, or a supercharger. Intermediate overlap, short duration cams are chosen to prevent the boost from shooting into the exhaust manifold with a long cam overlap.
eg. intermediate overlap short duration cams for forced induction:
for B18A/B - Crower 62402/62403, Crane 101-0014 turbo cams
for B18C - Toda Spec A, Jun Type 2, Crower 63402/63402A, Zex/Compcams 57100 or 57200, Crane roller 253-0510 cams with roller rockers.
However, with more intake cam duration there is a greater chance of cylinder pressure being lost out of the opening intake valve. We lose dynamic compression . Along with High Piston Speeds Away From TDC, big overlap cams will reduce cylinder pressures and prevent efficient burning or combustion of the air fuel mix.
__________________________________________
www.floridasportsman.com
Originally Posted by P057
"Wow I had a hard time understanding that... but from what I gather you found an open-box item that wasn't cheaper. You bought it anyways. You then called someone a dumbass while making fun of their misfortune of losing a job as you were leaving the store?
I'm surprised you were able to get out the store with that big "SUCKER" sign affixed to your back.
Old Apr 24, 2007 | 12:51 PM
THATdamnFAST's Avatar
lol bascially what he said
Im as smart as a horse and hung like einstein
Old Apr 24, 2007 | 01:08 PM
code 52!!
thanks for the great info
