whats a good aftermarket ls cam
However, with more intake cam duration there is a greater chance of cylinder pressure being lost out of the opening intake valve. We lose dynamic compression . Along with High Piston Speeds Away From TDC, big overlap cams will reduce cylinder pressures and prevent efficient burning or combustion of the air fuel mix.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
thank you for sharing what you know with me. i read all that i can and try very hard to gain full understanding of how this machene works. thanks again. kyle
__________________________________________
www.floridasportsman.com
Originally Posted by P057
"Wow I had a hard time understanding that... but from what I gather you found an open-box item that wasn't cheaper. You bought it anyways. You then called someone a dumbass while making fun of their misfortune of losing a job as you were leaving the store?
I'm surprised you were able to get out the store with that big "SUCKER" sign affixed to your back. "
keep on reading. seems like you have a fair grasp of what is going on. find something that you feel you need to be knowledgeable in and work on that. cars in general is such a broad spectrum not many people can completely encompass it.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
