Vtec and non-vtec turbo
Old Apr 23, 2007 | 06:07 PM
D.A.'s Avatar
Default Vtec and non-vtec turbo
This is a questions that i cant seem to get a straight answer on and idk if its been posted before but im hoping someone can point me in the right direction.
some of my friends say vtec helps when turbos other
say better non vtec honda better turbo. why is it better or why is it not better? whats ups and downs to having non-vtec turbo to vtec turbo? for honda ofcourse
Old Apr 23, 2007 | 06:27 PM
sleepinsol's Avatar
starting over
vtec is really just a race cam that kicks in at 5500 rpm. any bigger cam is going to help a turbo out. bigger cams make more power. all the turbo does is cram more air/fuel into the motor. granted i wouldnt put huge all motor cams in my turbo set up bc it wont run rite, but stock vtec cams would help the turbo out. keep in mind u wont b able to run as much boost bc of the higher compression, but that doesnt necessarily mean ull make less power.
Old Apr 23, 2007 | 06:32 PM
D.A.'s Avatar
well still will it affect the power is what im saying i understand what vtec is but which would help out more. keeping the vtec in ur turbo set up or taking it out?
Old Apr 23, 2007 | 06:57 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
keeping vtec will of course give you more power.both have their pros and cons.
imo ls/vtec turbo will produce the best power out of any b series if built properly.
-Winston Churchill
Old Apr 23, 2007 | 07:37 PM
Pyroproblem's Avatar
Porsche Tech/Honda Tech
turbo honda are good.
turbo vtec hondas are better.
The only benefit of no vtec is cost.
Now residing in Atlanta.....
Old Apr 23, 2007 | 08:52 PM
sleepinsol's Avatar
starting over
+1 on ^^^^^
Old Apr 23, 2007 | 09:23 PM
nolexforever's Avatar
as said already, VTEC and turbo is great together. high compression and turbo isnt so great.
Old Apr 25, 2007 | 05:44 AM
Da1andonlyJinx's Avatar
eh, such as life
Okay, you know when vtec kicks in it flows more oil through the the head right, well depending on the size of the turbo you might not get the required amount of oil to supply the turbo while in vtec, also it is easier to tune non-vtec because there is not a power band where you have to add more fuel and so forth when the vtec kicks in. Do ya see what I'm saying? Also you could have 10 to 1 compression and still boost, It is just alot more difficult to tune because you have alot less margin of era. The less compression you have (not to low) the more of an area you have to tune. I hope this helps.
Rep me up.
Old Apr 25, 2007 | 08:32 AM
sleepinsol's Avatar
starting over
+1 on the above...the vtec will b harder to tune, but its been done so its a mute issue. there are soooo many performance turbo shops that can tune vtec turbo setups now. but the above point is correct.
Old Apr 25, 2007 | 08:35 AM
Presidential_Detail's Avatar
aka The Twanksta!
Non Vtec Ftw!
Visit Our Site - Presidential Automotive Detailing
Authorized CQuartz FINEST Installer
